Using SMC to Verify Compliance with Guidelines
Solibri Model Checker is widely accepted as the leader in BIM-based quality assurance checking. Quality assurance can also include measuring compliance with Guidelines that have been established at the micro or macro level (process, project, agency or even territory). While there are many examples of BIM Guidelines, the process of checking them, in most cases, […]
Solibri Model Checker is widely accepted as the leader in BIM-based quality assurance checking. Quality assurance can also include measuring compliance with Guidelines that have been established at the micro or macro level (process, project, agency or even territory). While there are many examples of BIM Guidelines, the process of checking them, in most cases, will remain the same: a list of requirements for the project is converted to rules that will be consistently applied to validate the model and to verify that it adheres to these requirements.
Using several different rule templates, you can build a ruleset that reflects the BIM Guidelines. Listed below are example requirements from the Massport MPA Bim Guidelines, along with the corresponding template that would be used to convert the requirement to a Rule in SMC.
BIM Guideline Requirement  Solibri Model Checker (SMC) Rule Template
OmniClass Spaces by Function (Table 13) Property Rule Template with Component Filters Rule + Classification
Dimensions of components are accurate  Property Rule Template with Component Filters Rule component dimensions are greater than / less than minimum/maximum values.
Model Elements must exist  Model Should Have Components
Floor to Floor distances  Floor Distance
Space Naming Requirements Property Rule Template with Component Filters Rule + Classification
Space ID/Number Requirements  Components Must Have Unique Identifier
Spaces greater than 9 sqft must be modelled  Space Validation : Check Unallocated Space
Room spaces are completely enclosed by walls  Space Validation : Acceptable error in space perimeter
Gross Area Calculations  Floor and Gross Area Analysis
Usable/Rentable Area Calculations  GSA Extension
ADA Checks Accessible Door Rule
Accessible Ramp Rule
Accessible Stair Rule
Accessible Window Rule
Free Floor Space
FM Data Validation COBie Extension
Clearance Requirements Free Area In Front Of Components
Component Distance
Clash Detection General Intersection Rule
Allowed Beam Intersections
