Creating Presentations on-the-Fly in SMC
The core functionality of Solibri Model Checker (SMC) is to run rules-based checks on your Building Information Model (BIM), review the results of those checks, and generate issue slides of those results to create a presentation/report of issues. The presentation and report can be generated automatically by selecting the “From Checking Results” option in the New Presentation dialog.
You can also create presentations manually during your coordination meeting by creating your own issue slides outside of a rule check. The following article will demonstrate this simple function, which can be useful when you are getting started with SMC or if you want a quick way to create snapshots of your model on-the-fly. You can follow along using the SMC Building.smc model that comes with SMC located in the Models folder in the program files.
After opening the SMC Building.smc sample model, you’ll notice in the Checking layout, that a rule check has already been run on the model and issue slides have been created for some of the results of the check:
You can tell a slide was created for this result as a slide icon appears next to the result.
If you select the Communication layout, you’ll see there are two presentations listed in the Presentation view. The “Issues (12)” presentation is a presentation created from checking results. Below you see the issue slide previously seen in the Checking layout.
You can tell these slides were created from Results as there is result link icon shown on each slide in the Issue Sorter view.
To create a presentation from checking results, after clicking the New Presentation button in the Presentation view, click the “From Checking Results” option and mark the Rules you want slides created for in the Presentation.
If you look in the Presentation view, you’ll see a presentation named “General Presentation (4)”. There are no result link icons shown on the slides in the Issue Sorter view. This is because this presentation was created without the means of checking results. To create a presentation of this sort, in the New Presentation dialog, mark the first option “New.”
You can then add issue slides manually by right-clicking on a slide in the slide sorter, and select “New Issue” option.
Below, we selected the 4th issue of the “General Presentation” in the Issue Sorter. We then zoomed out to the front wall, made the wall transparent and added some markup using the Markup tool stating that the water closet room needs a toilet:
After right-clicking the 4th issue slide in the Issue sorter, we select New Issue. A new issue slide is created in the presentation with the visualization saved and we can add a title to the slide.
From there, we can add more slides manually in this same way without the need of having an actual checking result.
