License Error: Associated version number (9.5) is smaller than required version number (9.6)
If you try registering Solibri Model Checker (SMC) v9.6, and find the error, it is due to only having a version 9.5 license assigned but not the required 9.6 license:
Associated version number (9.5) is smaller than required version number (9.6)"
To resolve the issue:
- Log into https://solution.solibri.com as an admin user.
- Select the License Assignment tab.
- Leave the Product radio button marked, and select Solibri Model Checker.
- In the version list, select 9.6 and click Refresh.
- Mark the checkbox for the users that will be running version 9.6 of SMC.
- Click Assign.
Those users should then be able to run version 9.6 of SMC.
The info column lists the versions of SMC licenses that are assigned to a user.
You can also quickly upgrade the versions of assigned licenses by clicking the Upgrade button.
After upgrading all 9.5 licenses to version 9.6, all users that had version 9.5 or both 9.6, 9.5 assigned are assigned version 9.6 licenses..
