BIM Data Validation: It’s Not Just Geometry
Diagram titled "Geometry tells you where. Data tells you what." A door that is geometrically correct links to its attached data. The fire rating, manufacturer and classification are all missing, so the door is not useful for specification.
Building information modeling (BIM) has transformed the AEC industry. Modeling the project in 3D brought disconnected 2D drawings together. Suddenly, teams could see where solids intersected, avoiding those clashes.
But like any good technology, BIM continued to evolve. Teams added more and more metadata to model elements. In doing so, they progressed beyond a geometric representation of the space.
“BIM is often seen purely as a 3D representation of the building, but in reality, it’s equally a structured database of information behind that geometry.”
   — Patrick Lalonde, Vice President of Digital Project Delivery at EllisDon
Validation processes haven’t necessarily caught up to that reality. Many checking processes look for geometric issues but don’t assess the underlying data. That’s a problem because a model can be geometrically correct and still fail downstream workflows. As teams increasingly rely on model data for estimation, analysis, and operations, this becomes more and more problematic.
The many problems with unvalidated model data
“It’s not as much about the geometry. It’s about the data. Typically, the geometry is only carrying the data we need.”
   — Allen Angle, Senior VDC Manager and Owner’s Digital Representative at VIATechnik
As a result, a model can be clash-free and still unusable. Geometry tells you where something is. Data tells you what it is. If that data fails, downstream processes can, and often do, break down.
Take a door as an example. It might be geometrically accurate in the model. But if it doesn’t have underlying metadata about its fire rating, manufacturer, or classification, it’s not useful for specification.
“[Unvalidated data] creates friction everywhere. Cost estimation, scheduling, facility management, and digital twins all depend on reliable data. When that data is inconsistent or incomplete, teams often have to rebuild it manually. That not only adds time and cost, but also reduces confidence in the model. In many ways, the value of BIM is directly tied to the quality of its data.”
   — Niknaz Aftahi, CEO and Founder of aec+tech
With so much at stake, you could wonder why teams aren’t doing more to make sure model data is complete and accurate. In many cases, the answer is surprisingly simple. “Most people just don’t know what to check or how to check it,” Angle explains.
Lalonde explores this further, saying, “Teams frequently struggle with inconsistent standards, unclear requirements, and poorly defined contractual expectations around BIM deliverables. Without a clear framework, different disciplines interpret modeling requirements differently, leading to misaligned outputs.
“In many cases, model data is still treated as a byproduct of design rather than a core deliverable, which results in gaps in structure, completeness, and accountability across the project lifecycle.”
Because requirements aren’t clear and teams aren’t trained in data validation, many models move forward with missing properties,  inconsistent naming conventions, incorrect classifications, and other issues. That undermines downstream processes.
What’s more, it means teams miss out on the efficiency gains that reliable model data can deliver, from automated material takeoffs to clean translation to facilities management systems.
The holistic data validation modern BIM needs
While the industry has been circling this issue for a while, leading companies have improved their systems and processes for validating model data. Lalonde explains the shift, saying, “In the same way we perform clash detection to validate spatial coordination, we need to apply the same rigor to validating the underlying data, ensuring that model information is complete, accurate, and consistent. This includes verifying model integrity, documentation, and version control, reinforcing BIM as an information management process, not just a modeling exercise.”
More rigorous validation processes require time and effort. But the payoff is often significant.
Data validation drives efficiency and accuracy. Validated data links to eight BIM uses, from 4D scheduling to digital permitting.
When teams have data they can trust, it drives more efficiency and accuracy in:
  • Cost estimation (5D BIM)
  • Digital permitting
  • Digital twins
  • Energy and sustainability analysis (6D BIM)
  • Facility management (7D BIM)
  • Prefabrication
  • Scheduling (4D BIM)
  • Quantity takeoffs
As those additional dimensions (i.e., 4D–7D BIM) highlight, the model is ripe with potential. Using it to its fullest extent requires consistent, holistic validation of the data it contains. When teams can rely on that data, it sets the foundation for more efficient, smarter, more successful projects.
“When the required data isn’t intentionally embedded, these workflows can’t be executed effectively, limiting the value of the model,” Lalonde says. “To fully realize the benefits of BIM, data must be purposefully defined and included based on the intended use cases and expected project outcomes, rather than treated as an afterthought.”
The specifics: What data validation means in BIM
Same object, four different names. Before validation, a fire door is named four ways. After, every model uses DR-FD-01.
What does it mean to validate the model beyond checking the geometry? In short, it means getting property data to the point where downstream teams can trust it without having to recheck it.
“Data validation is really about trust. It’s not just about whether elements are modeled correctly, but whether the information attached to them is complete, consistent, and usable.”
That requires teams to check for:
  • Consistent naming and labeling conventions, even across disciplines
  • Correct mapping of shared parameters, systems, and space relationships
  • Proper object classification
  • Property completeness for objects and required property sets, including details like materials, asset IDs, manufacturers, and performance data
  • Standardized unit, measurement, and formatting conventions
They also need to check that the model doesn’t contain duplicate or blank values.
All of this gets much easier when companies make a few choices. First, they should implement standards. That way, teams can validate model data against those standards. That could mean using established frameworks like Information Delivery Specifications (IDS). Or it could mean laying out guidelines in the project’s BIM Execution Plan (BEP) or the other documentation that will guide virtual design and construction (VDC), like a Project Execution Plan (PxP).
Secondly, they should look for ways to automate the data validation process. This shifts it from a burdensome checklist for individual team members to a strategic QA tool the whole company can use. Just as importantly (if not moreso), it validates the data per the owner’s requirements.
Finally, companies need to establish a way to track and resolve data issues that get identified. It’s one thing to flag a problem. Truly useful, reliable models require that those problems get addressed.
Laying the foundation: Validating data early and often for optimal building lifecycles
The later a data issue is found, the more effort it takes to fix. Illustrative curve rising from authoring to handover.
As with most things in the AEC industry, catching data problems early (e.g., during authoring, coordination) makes them cheaper, easier, and faster to fix. If they make it to the construction phase and get caught in the field or, perhaps worse yet, at handover, they present a much larger headache.
“What I’ve seen consistently is that early validation has a compounding impact,” Aftahi says. “When data issues are identified early, they’re relatively easy to resolve. When they go unnoticed, they propagate across disciplines and phases.”
She explains that teams that prioritize early validation tend to reap rewards like:
  • Better decision-making
  • Improved coordination
  • Reduced rework
  • Stronger consistency across deliverables
“This is where BIM starts to function not just as a modeling tool, but as a reliable source of truth,” she says.
“Early data validation provides certainty and confidence early in the design process, enabling teams to make better and more accurate decisions. When data is validated upfront, it ensures that downstream coordination and analysis are built on reliable information, reducing risk and avoiding costly corrections later in the project lifecycle.”
As an owner’s rep, Angle has a unique perspective here. He regularly sees how reliable model data translates to smooth handover and strong facilities management, while missing or inaccurate data spells long-term trouble. When his team has the data they need, it becomes a powerful tool.
“The data we can get from BIM and VDC can help us downstream, sometimes in ways the model can’t, and that goes back to being able to validate data,” he says. “Most of our organizations are going to have some unique ID that’s part of their lifecycle system, that goes into their operations or digital twin tool. We have to start that digital thread upstream. Then we can track any type of data we want.”
Building your strategic model validation framework
When teams start validating model data early, then consistently check it throughout the project, it unlocks more potential in BIM. You don’t just avoid clashes. By going beyond geometry in the model, you create a valuable asset that can be used across disciplines.
Teams can estimate more accurately and schedule more strategically. They can automate historically burdensome processes like quantity takeoffs and compliance checks. They can tap into advanced tools like energy analysis simulations and larger-scale prefabrication.
In this way, model data validation doesn’t just reduce rework. It becomes a strategic tool AEC companies can use to gain a competitive edge. They can make data-informed decisions to model data that owners can carry into their facilities management systems.
While moving from geometry checking to holistic data validation does require a major perspective shift, it doesn't have to start as a major lift. Teams can begin with the data their next project depends on most, then build from there. With Solibri, teams validate geometry and data in one platform, checking for clashes alongside classifications, property sets, required parameters, naming conventions, and information completeness. Reusable rulesets can be matched to project requirements, owner information requirements, or IDS files. To see how Solibri can become a strategic part of your processes and support stronger deliverables, talk to an expert.
