SMC and SMV v.9.7.11 Maintenance Release Notes
Below are the details of the maintenance release notes for both Solibri Model Checker (SMC) and Solibri Model Viewer (SMV) v.9.7.11:
Solibri Model Checker Main Updates:
Change in username
Until now, users have only had the possibility to set the username seen in reports. With this release, the username will be the same as Solibri Solution Center (SSC) username or a ‘Reporting Identity’. This change allows better control and a more consistent usage of identifying the user who has created a report or issue. (The change to add a Reporting Identity is done by the SSC administrator if it is wanted).
Saved layout sets
From version 9.7.11, it was possible to save different layouts for different roles within your team. Now there is a new dialog in Settings -> Layout Sets. This allows you to save layout sets that can be used in roles and company extensions.
SMC Trial File format
Models also saved by a SMC trial license now have their own file format. Those files can be only opened by the same user who has saved the model. If the user is using a ‘normal’ SMC license, the model can be saved in the regular SMC format.
SMC small improvements and bug fixes
As with any maintenance version, there are small improvements asked by multiple customers. These include:
- Project as a location type in Information Takeoff – this allows the addition of a time stamp and other IFC header information to be included to ITO reports
- Visual indicator of new or updated extensions to help users to know when they should install or update an extension
- More clear information of SMC usage levels inside a company – utilization percentage in peak report (statistics in SSC) takes company working hours into account (8 hours by default)
