Solibri 9.13.7 Release Notes
This maintenance release focuses on improving the existing features, such as integrations, drag & drop functionality, IFC, and fixing commonly reported bugs. Update to the new version to get the optimal performance.
Improvements and bug fixes
Integrations:
  • The SharePoint integration was changed to require access only to selected sites instead of all. This means that organization admins can configure themselves which SharePoint sites Solibri can access.
  • Fixed an issue where SharePoint and OneDrive login in Japanese and French didn’t work.
Drag and Drop:
  • Fixed an issue where numeric properties of a property set dropped to ITO were summed incorrectly.
  • Fixed an issue where bounding box quantities dropped to ITO were changed when editing later.
  • Fixed an issue where bounding box quantities dropped to Filter were changed when editing later.
IDS:
  • Added support for property applicabilities to IDS rule. Now, it’s possible to select components to check based on properties.
  • Fixed an issue where special characters of IDS were shown incorrectly in rule parameters.
  • Fixed an issue where the IDS rule didn’t save IDS as UTF-8.
  • Changed the IDS rule to use Solibri common file open dialog with recent files.
IFC:
  • Improved correction of invalid transforms in IFC import. This improves the positioning of components that were incorrectly located.
  • Fixed an issue where IfcSurfaceStyleShading.Transparency was not imported correctly from IFC4.
  • Fixed an issue where IFC profiles were placed incorrectly based on mass center properties.
  • Optimized special cases where IFC models with reinforcing bars took a long time to load.
Info View:
  • Fixed an issue where the angle property was shown as radians instead of degrees in the Info view.
  • Relations of the type object are now shown in the Info view.
  • Fixed an issue where the space number was shown in the category of nearest spaces in the info view.
Rules:
  • Fixed an issue where rule #1 visualization was not working. The problem was introduced in 9.13.6.
  • Fixed an issue where Rule 209 didn’t show extra UI controls when the classification option was selected.
API:
  • Fixed an API issue where SMCChecking.getChecking().getResults(rule) didn’t produce results.
  • Fixed an API issue where Result.setSlide() didn’t set the slide correctly.
  • Fixed an API issue where sections are not shown in Visualization.
Other:
  • Optimized the model closing time.
  • Removed needless Java VM options: -XX:+UseG1GC and -XX:+AggressiveOpts
  • Fixed an issue where the ITO column editor was not showing the help text for all column types.
  • Fixed an issue where the perimeter of decomposed roofs was calculated incorrectly.
  • Fixed an issue where the filter row state was rendered as grey in some cases.
  • Fixed an issue where GPU memory was leaked in rendering
  • Fixed an issue where update model dialog was not painted due to errors with remote files.
