Solibri Model Checker Release Notes v9.8.17
This maintenance release focuses on Japanese support and PDF handling among other improvements:
Japanese support:
- Version and documentation
- Improved picking when moving PDF
- Visibility in slides
- Possibility to pick measurements through transparent areas on PDF
- [#235] Remove extra brackets in issue title
- [#236] Improved issue categorization
- [#236] Improved visualization in issues around staircases
- [#1] Sometimes components that didn't even touch created issues
- [#1] Sometimes the "Light fixture whose lower elevation matches the elevation of suspended ceiling" exception created issues
- You can now pick the drawing from 3D and see its info
- Improved picking of drawing lines and intersections
- Improved performance on PDF import
- Transparent areas of PDF don't block picking anymore
- PDF drawings as footprints now properly working
- Cropping doesn't create black areas in the PDF anymore
- Align drawings is now undoable
- PDF can now be added to selection basket
- Improved interactive placement of drawings
- Added support for predefined Type for IFCTYPE objects
- Calendar component is now localized
- Improved icons
- Footprints are now shown when spaces are reported in ITO
- ITO tables now scroll properly
- IFCFLOWTERMINAL in ITO now only reports flow terminals
- Mac - Improved 3D performance
- Section plane selection improvements in 3D view
- Navigation map floors are now properly updated
- Double clicking the cell in checking results now creates a slide
- Issue sorter dialog performance improved
- Flagging in the issues window has been improved
- Issue date is now saved properly
- PDF visibility now works with slides
- Ruleset Manager: Text editing in description popup window has been improved
- Category removal from pop up menu improved
- Update models popup doesn't load all files
- Classification tables now scroll properly
- Nearest Space: Relation is shown after relating a component to another space
- Model tree sorts the models according to their short names
- Model tree sorts the models if the model name gets a new short name from popup menu
- It is possible to select a component from component type selection dialog by double clicking on the row
