Solibri Model Checker v9.5.23 Release Notes
Release Version: 9.5.23 Release Date: 29/04/15
IFC Import Related
- Optimized and fixed importing of IFC type object not to merge types with identical names, but different guids
- Fixed problems when some components were misplaced after updating an IFC file
- Improved importing of IFC header information. They are now shown as property sets of project, so that they can be used in rules, classifications, and ITOs
Geometry and performance
- Improved checking performance
- Improved calculation of footprints in models that are far from origin
- Improved calculation of curtain wall areas
Communication & UI
- Snapshots were taken from wrong location when the size of items was not equal to the natural resolution (make items smaller or larger in Windows Control Panel)
- Model tree modified not to show children of decomposed object at wrong level, when object decomposition has more than one level
- Improved display names of deeply nested decomposed objects
- Floor numbering improved in case of multiple building instances in one IFC model
- Removed redundant lines in PDF and RTF reports
Classification
- Fixed numeric classification rules to work with decimal format
ArchiCAD Link
- Fixed importing of property sets with Boolean and integer properties using ArchiCAD direct link
Rules
- #179 Routes on stairs looked bad in models located far from origin
BCF
- Fixed the case where header information was sometimes empty when exporting BCF 2.0 file
- Added support for component color when it appears as empty string when importing BCF 2.0 file
Installer
- Installer is now signed and certified on Mac platform - no more problems with security
