Solibri Model Checker v9.5.24 Release Notes
Release Version: 9.5.24 Release Date: 17/6/15   BCF Related
  • Several BCF 2.0 compatibility issues fixed
  Issue Management
  • When adding slide to several selected issues, only the first issue got the decision (rejected/accepted)
  •  When adding slide to several selected issues, location information and components were not filled properly
  • When adding slide for a component in results, decision was not set
  Rules
  • Rule#203: All models were included in the results when models from only selected disciplines were checked
  • Rule#203: No issues were created for missing properties or property sets when Optional was selected in Value Exists
  • Rule#1: Rule exceptions didn't consider decomposed walls
Performance
  • Checking performance improved by optimizing model volume calculation and separating that to an own thread
  Quantities
  • Calculating of wall height was incorrect in a special case
  Filtering
  • Filter with classification and contains operator didn't work when loaded from a file
  IFC
  • Updating of model with a newer IFC version didn't always produce the correct results
  Misc
  • Added support for covering in material map
(Please note: Existing add-ons continue to work (e.g. Swedish Extension) with this release)
